October 25, 2021 at 11:14 pm
hani.sadek_i
SubscriberHello,
I am doing scripting with MotorCad and I'd like to know if there is a command that I can use to extract winding factor and mmf values. This is really important as it will save the time copying the data manually to matlab.
In addition, I have realized that the command:
invoke(mcad, 'DisplayScreen', 'Electromagnetic')
doesn't work. Am I doing anything wrong here?
Thanks !
October 27, 2021 at 7:09 pmHDLI
I am not sure why you use this command. Here are some information.
1). Please review scripting tutorial "ActiveX_Scripting.pdf" and Matlab scripting example folder "ActiveX", located in MotorCAD installation folder, C:\ANSYS_Motor-CAD\14_1_17\Tutorials.
2). Find parameter names of winding factor and mmf in Help, or select value while clicking F2 to get the parameter name.
3). Use the command like [success,ShaftTorque] = invoke(mcad,'GetVariable','ShaftTorque'); to get parameter value.
Thanks.
HDLI
November 1, 2021 at 4:11 pmhani.sadek_i
SubscriberHi
I've done all that.
I am just asking how to extract the winding factors and mmf values.
Is there a way to get these values in matlab?
Thanks
November 23, 2021 at 6:05 pmhani.sadek_i
Kindly, could you reply to my question regarding the extraction of winding factors and mmf values from within the matlab scripting?
The reason i need this is that i want to plot these values for different parameters changes.
Hani
Viewing 3 reply threads- The topic ‘MotorCad Scripting’ is closed to new replies.
6660
1313
