Electronics
Electronics
Assign band for Axial Flux Generator in Maxwell
    • user deleted
      I'm trying to assign a band for the motion of the two rotors in Axial Flux Generator that are separated by the fixed stator.
      The problem is that I can't contain the two rotors in single band due to the configuration of the machine and I can't exclude the stator from the band either.
      Any idea of how I can do this?
    • NKC
      Hi @oss7m You can apply two bands and still get the result.
      Refer to the below forum discussion.
      apply motion for double rotor ÔÇö Ansys Learning Forum
      Regards Navya
    • user deleted
      I solved the problem by Uniting the two bands into one geometry.
      Thanks for your help.
    • phuonganhlovely.me
      hi oss7m
      have you finish your project ?
      i am doing design axial flux motor too. but i get the back emf have ripple how can i solve this problem?
      the other problem is the induce voltage is not reach to my desire
      best wishes.
  • The topic ‘Assign band for Axial Flux Generator in Maxwell’ is closed to new replies.
