Total deformation vs Directional Deformation
    • ozdmrdnz
      hello everyone,
      Whats the difference between total deformation and directional deformation if we modeled simple midspan load beam. I expect these two thinks give us a same result because there is only Y direction force effecting our beam but its not worked
      cause I'am trying to set the model for sandwich structure, I just told you how I am try to think that model as simple as I can so that I gave a example for simple midspan beam
      Best Regards
    • hesamkeshavarzz
      They are the same only for Euler-bernoulli beam! neither for Timoshenko beam element nor solid elements.
    • ozdmrdnz
      thank you for your reply
  • The topic ‘Total deformation vs Directional Deformation’ is closed to new replies.
