July 7, 2021 at 1:19 am
ManoelRSNeto
SubscriberError: 80004005
Hello, I have the following error (as per screenshots).
It was running normally with the program, but now it is correcting the following error when trying to analyze modal systems and harmonic responses
I tried the following solutions:
/forum/discussion/12753/unable-to-edit-mesh - unsuccessfully
/forum/discussion/11845/getting-a-script-error-code-80004005-line-45377 - unsuccessfully
July 22, 2021 at 7:37 pmGeorge Karnos
Ansys EmployeeCan you try the following: Verify all Ansys programs are shut down.
Browse to %APPDATA%\Ansys
rename v212 to v212.old
212 is for 2021 R2, please adjust to which version you are using.
June 5, 2023 at 1:58 pmNadiia Kopiika
SubscriberHave yiu managed to resolve this problem? I have error 80004005 if (report Preview Pane.Pane.Selected) when starting Mechanical. I have tried everything recommended here, but it did not help
November 14, 2023 at 12:29 pm
nicholas.bizinos
SubscriberHello Nadiia
Did you resolve this? I am getting the same error you reported.
Viewing 2 reply threads- The topic ‘Error: 80004005 Ansys 2021 R1’ is closed to new replies.
3797
1388
1188
1095
1015
