July 5, 2021 at 1:30 pm
nishantsinghbme
SubscriberI am doing LS dyna analysis of simple cubic structure with a top plate with velocity 1000 mm/sec and bottom fixed.
Analysis was performed well.
Now I want to do density based topology optimization. For this when I am setting Objective then in response constraint I am unable to set up response . Kindly help. Image is attached below. Thanks
July 5, 2021 at 2:27 pmpeteroznewman
SubscriberRead the ANSYS Help and you will find this helpful information:
Prerequisites and Requirements
The Topology Optimization analysis must be linked to (preceded by) a:
Static Structural
Modal
Steady-State Thermal
Static Structuralin combination with either aModalor aSteady-State Thermal
The loading and/or boundary conditions defined in your upstream system are used to create an optimized part based on the objectives and constraints specified in theTopology Optimizationanalysis.
July 5, 2021 at 3:20 pmnishantsinghbme
SubscriberThanks for prompt response.
I am worried for the topology optimization that can only be done with linked structural analysis/model in ansys.
However, I am trying to replicate similar work performed in paper titled "advanced lattice material with high energy absorption based topology optimization"
In this paper author had used lsdyna along with topology optimization .
If any idea please tell me.
Thanks
July 6, 2021 at 2:22 ampeteroznewman
ANSYS Topology Optimization does not currently support an LS-DYNA analysis.
I expect the authors of that paper have written their own custom version of Topology Optimization for their research.
July 6, 2021 at 3:25 amnishantsinghbme
SubscriberOk that is the main reason for not working. Thankyou very much for clarification.
July 6, 2021 at 3:30 ampeteroznewman
SubscriberSeptember 8, 2021 at 6:51 amspiderman
SubscriberHello, I think you should make the lattice model first and then do the energy absorption simulation. As far as I know, topology optimization cannot be optimized into a lattice structure.
Viewing 6 reply threads- The topic ‘Unable to optimize shape in topology optimization problem’ is closed to new replies.
3572
1188
1076
1063
952
