June 27, 2021 at 3:04 pm
iamhsafi
Subscriberhello! i am simulating a high power transformer in maxwell and i have to give a square wave with 50% duty cycle as an input to the coil terminals. I would really appreciate it if you could write it in the exact words as i am supposed to write it in maxwell. The frequency is 20khz.
July 1, 2021 at 4:25 amNKC
Forum ModeratorHi @iamhsafi you can use a pwl function to define the square voltage.
You can look at the following forum discussion for how to define a pwl function. Change units appropriatly
/forum/discussion/comment/116644#Comment_116644
Please refer to Maxwell help document for more detail on defining pwl functions.
Regards Navya
July 12, 2023 at 2:05 pmKyrylo Kalashnikov
SubscriberHello! Thanks for the help. However, it looks like the link that you are referring is not working anymore?
July 13, 2023 at 2:44 pmGLUO
Ansys EmployeeHello,Â
Method 1 insert a dataset and use pwl(datasetname, time)
Method 2 use sgn(sin(2*pi*time*Freq))
Method 3 use external circuit and pulse source
GL
July 14, 2023 at 5:08 pmGLUO
Ansys EmployeeHi,
Correction Method 2 use 0.5*(sgn(sin(2*pi*time*Freq))+1)
GL
Viewing 4 reply threads- The topic ‘how should i write the equation for a square wave with 50% duty cycle as coil input in maxwell?’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Co-simulation in Q3D, Icepak – meshing problem
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
Top Contributors-
4597
1495
1386
1209
