May 17, 2021 at 2:18 pm
KCHENG
SubscriberHi,
I am writing a journal file to sbbmitting my unsteady job to hpc cluster.My journal file is like this:
rc probe-in
sta-init
time-step 0.001
dual-time-iterate 2000 50Â Â Â Â
wcd probe-out
overwrite ok
.out and .err:
May 17, 2021 at 4:16 pmAmine Ben Hadj Ali
Ansys EmployeeI recommend to record a journal with all commands you require. Fluent will just keep track of the correct commands. Under File start journal, you can start recording: that is the best way .
Ansys Employee/solve dti 2000 50
May 18, 2021 at 12:56 pmRob
Forum ModeratorAlso, click into the text window and press Enter. You'll see a list of commands, type in the command you want and press Enter. Press Enter again to see the next menu list. Use q (Q) to move back up the tree.
/file/rc probe
Is the correct form and avoids issues with menu level mismatches as it uses the top menu level as the starting point.
Viewing 3 reply threads- The topic ‘Write journal file for a unsteady job’ is closed to new replies.
4858
1587
1386
1242
