TAGGED: charge, lumerical, photonics, solar, temperature
May 5, 2021 at 11:05 pm
sanjum
SubscriberI'm trying to follow the planar silicon solar cell example. I'm able to follow it through and obtain the results shown at this page when I don't import the temperature profile during the electrical simulation and simply run CHARGE with an isothermal temperature distribution. However, when I tried running it with the temperature data I had obtained from HEAT (which ran fine and gave me the desired result), it would not work. I am unable to attach any of the relevant files, however. Any help would be appreciated!
May 6, 2021 at 9:12 pmMucteba13
SubscriberSame problem here.
May 7, 2021 at 1:28 pmkghaffari
Ansys EmployeeHi Thanks for reaching out. When including the heat effects in your CHARGE simulation, what temperature dependence mode are you using (in the solver settings)? Please note that the coupled mode can not be used here since fluids (here air) can not be simulated in coupled CHARGE simulation. Here to include the thermals you can use the non-isothermal mode. I tested this mode as instructed in the article and the project seems to work.
Kind regards
May 7, 2021 at 2:43 pmMay 7, 2021 at 3:11 pmMay 7, 2021 at 4:35 pmMay 7, 2021 at 9:21 pmMucteba13
SubscriberIn summary, both of us could never see the temperature effect in electrical simulation.
May 13, 2021 at 4:43 amsanjum
Subscriberor another employee, can you please help us further?
May 17, 2021 at 5:37 pmkghaffari
Ansys EmployeeThanks for further explaining this. The attached results match what is expected and published in the article.
Like you mentioned the issue is the non-isothermal mode not working for you. This is unexpected; I tested the example on different versions of the software and the non-isothermal mode works for this project. I will follow up on this with you shortly.
Viewing 8 reply threads- The topic ‘Planar Silicon Solar Cell Example Not Converging with HEAT data’ is closed to new replies.
3597
1243
1092
1068
953
