April 29, 2021 at 6:45 am
ZunNooren
SubscriberHello! I get the same error. I am running Fluent in serial and I'm not using any UDF. I am dealing with the analysis of wind turbine. There are two fluid domains one is stationary and other is rotating. I have tried it on parallel as well but the same problem occurs. Happens whether I use hybrid initialization or standard. I don't know why there is memory error as well because my system specs are 16 GB RAM, more than 400 GB in working directory and more than 100 GB in C\:. I am using ANSYS 19.2.
May 2, 2021 at 3:08 pm
System
SubscriberThis discussion was created from comments split from: Got a problem with "mpt_accept: error: accept failed: No such file or directory". -
May 2, 2021 at 3:09 pm
Forum ModeratorHow many cells have you got? That looks like you're trying to model something that's too big for the system RAM.
- The topic ‘ST_Create_Store’ is closed to new replies.
1587
1386
1242
