September 26, 2020 at 3:11 pm
Balli
SubscriberHello everyone,
I have 8 platforms to calculate weight capacity. (Figure Model,model2 and model3) And my computer is not able to perform the analysis for shell models. Because of some platform models too big even I use symmetry. That's why I don't want to use shell models. I thought I can model beam and shell together. The general model will be beam and critical regions will be shell. I will use a rigid connection between them. But the problem is the center of gravity. When I transform the 3D to 1D lines are going different height because of the cross-sections. I'm moving them to the same level but at this time the model is changing. I mean the center of the solid model and the line are not going on the same height. If I move the solid to down, the geometry will change. Should I neglect that situation? It's really hard to explain what I'm trying to explain, but if you check the figure you'll see the red boxes that I want to highlight the regions. If I move the solid to down the connection will be changed. Is it acceptable? (Figure 1,2 and 3)
Or the second option is to use the original center of gravity for all of them. But how can I connect these beams that are located at different levels? (figure problem2.1, problem2.2)
September 28, 2020 at 11:18 amAniket
Forum ModeratorAnsys staff can not download images on the student portal, so if you want to reach a larger audience to get answers from, please insert the images inline.
-Aniket
September 30, 2020 at 3:52 pmOctober 1, 2020 at 6:29 pmAniket
Forum Moderatoryou can use contacts right? or do you want to share nodes? You will have to turn shell thickness effect on and use larger pinball radius.
October 1, 2020 at 7:02 pmBalli
SubscriberActually, that's not the problem.
I want to use beam and shell elements together. I will connect them rigidly with fix joint. So there will not be a stress concentration at the connection point. But the problem is a centerline roblem between the center of the beam element and the center of the shell element. They are not in the same line as you may see the first and seventh picture above.
How should I deal with this? Should I move the shells in order to set the centers on the same line? Is this an acceptable approach?
Thanks for your reply.
October 2, 2020 at 1:05 pmpeteroznewman
SubscriberThe fixed joint can connect the end of the beam with the offset edge of the shell elements and transfer the load. Don't move any beams or shells, that would be changing the geometry you are trying to simulate.
October 3, 2020 at 6:47 amBalli
SubscriberGreat peter!
Thanks for your reply. I was so confused about whether changing the geometry or not. I am going to try this way.
Viewing 6 reply threads- The topic ‘How to model beam and shell together?’ is closed to new replies.
4618
1530
1386
1210
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
