Test Materials for Additive Manufacturing — Lesson 5
Question - Are there any additional additive manufacturing materials available in Engineering Data for testing purposes in Mechanical?
Answer - Attached is an engineering data xml file that includes some properties for AlSi10Mg & 17-4 PH Stainless Steel. These properties are not from AM material sources, so be careful because they may not give the most accurate answers. However, these properties are likely better for AM simulations than other aluminum properties already available in the workbench.
Click here to download the associated files.
