Efficiently Meshing Layered Tetrahedral Elements — Lesson 7
How do you deal with question marks while using layered tets in Additive Wizard?
The following suggestions should help fix this problem, and the layered tet method control should become valid:
  1. Delete the body size control on the build part.
  2. Delete the Cartesian method control.
  3. Turn off adaptive size function and turn on curvature size.
  4. Manually generate required support prior to meshing and merge with the original build body, as automatic support body generation is not supported.
