Defining Frictional Contact as a Function of Sliding Velocity — Lesson 5
How can I define the frictional coefficient as a function of relative sliding velocity?
The frictional coefficient can be defined as a function of sliding velocity using the TBFIELD command
You can access the relevant files here: Download Files
For additional details, you may want to refer to the document below:
