Using Object Generator to Create Multiple Beam Connections — Lesson 2
When using an Object Generator to create multiple beam connections from an original connection, is it expected that one duplicate beam connection gets created?
This is related to the order in which the Reference and Mobile entities are scoped for the initially created connection. When you use Object Generator to duplicate the original connection, you need to respect the same order when pointing to named selections. If you reverse them, then the Object Generator will end up creating what appears to be an extra connection at the original location, but with Reference and Mobile scoping reversed from the original.
