APDL Example on Thermal Contact Conductance
Are there any ANSYS Mechanical APDL examples with the TCC (thermal contact conductance coefficient)?
The thermal contact conductance coefficient (TCC) is a real constant for the contact element. It represents thermal conduction through the contact and is used in the equation (q = TCC times (Tc - Tt) ), where ( Tc ) is the temperature at the contact surface and (Tt) is the temperature at the target surface.
Please refer to the attached steady state thermal analysis example.
