Viewing Unclipped Pressure Values
How can the unclipped pressure values be viewed when using the cavitation models in Ansys Fluent?
Unclipped solver pressures can be viewed by turning off the pressure limiter using the TUI command (rpsetvar 'mp/mt/limit-pressure? #f)
After executing this command, either save-reload the case and data files or run at least one flow iteration in the current session to populate the unclipped pressure values for post-processing.
For more details, refer to this document.
