Unit of Heat of Vaporization
The heat of vaporization is usually given in J/kg. The other SI derived unit is in Joule per mole or Joule per kilomol (kmol or kgmol) which is used by Ansys Fluent. How can I convert my input so that it might be used in Ansys Fluent?
In Ansys Fluent the dimension of the molecular weight is expressed in kg/kmol (kg/kgmol = kg per 1000 moles).
So to get the correct input of heat of vaporization or in general the standard state enthalpy of particular fluid at a reference temperature for Fluent the conversion below is required:
Standard state enthalpy in [J/kg]* Molar Mass [kg/kgmol] = Latent Heat in [J/kgmol ]
