Creating 3D Volume Cut Section and Displaying Contours
How to create 3D volume cut section and display the contours in Ansys Fluent.
Step 1: Cutting the 3D volume
Surface→ Create→ select the zone which needs to cut under “zone” option. You can select multiple zones as well.
Step 2. Iso-Clip the zone for the cut section
Go to Surface → Create→ iso-clip→ Specify the name of the surface under New surface Name. Select the variable to clip.
Step 3. Displaying Contours/Vectors on clipped Surface
Go to Contours→ select Temperature→ Static Temperature → Select the clip-surface (which created in the previous step)
Step 4. Similar plot for Fluid + Solid Zone ( zone clipped with z-coordinate)
Repeated the steps 2 & 3 for fluid & Solid zone together and display the static temperature.
For more details, refer to this document.
