Evaluating Heat Flux on Internal Zones — Lesson 9
How do you evaluate the heat flux on internal zones in Fluent software?
The heat flux on internals/interiors is not computed during the run. Therefore, you are not able to post-process it directly.
However, as a workaround, you can use a named expression like:
Sum(SpecificEnthalpy,['interface'],Weight ='MassFlowRate').
Be aware this expression is an approximation that does not include radiative and diffusive terms, but only the convective part. Also, this expression is only an approximation that shows limitations in accuracy for flow that is tangential to the internal. However, it is quite accurate if you have a flow normal to the internal. As a result, you should place internals in a way that the main flow path is normal to them if possible.
