How to save the setting of Ansys Fluent for one simulation and import to another simulation with a similar geometry?
The simplest way is to follow these steps:
Now all of the models, BCs, zone conditions, solver settings, etc. will be applied to the new model. Note that if the two models do not have the same topology (e.g., one has more outlets than the other, one has more cell zones than the other, etc.), Ansys Fluent will produce a warning, and you should verify to ensure that the boundary conditions and zone conditions are correct.
