How to delete an animation from a setup?
Solution Animations are available in the Outline under "Solution > Calculation Activities > Solution Animations" when the case is initialized. To delete or edit them use the context menu (right mouse click) for each entry. They are not available on the Calculation Activities Task Page.
Alternatively, use the text user interface (TUI) with the command
/solve/animate/objects/delete
