Exporting Report Plots
How to export Report Plots to a file?
User can easily define Report Plots and Report Files before running the simulation. However, sometimes user may decide to export the plotted data during/at the end of the simulation. Because Ansys Fluent stores this data, it is possible to do so with the command
/plot/file-set/plot-to-file [filename]
After running 1 iteration, Ansys Fluent will dump all data used in all the plots into the specified file.
