This lesson covers the various types of cooling methods used for electrical machines, including natural and forced cooling methods. It delves into the different standards as per NEMA and IEEE, and how these are specified in machine data sheets. The lesson also explains the significance of the IC (International Cooling) standard and how it represents the cooling method, circuit arrangement, type of primary coolant, and movement of primary and secondary coolants. The lesson provides examples of different cooling methods, such as self-cooling, forced cooling with machine-mounted independent components, and forced cooling with separate and independent components. It also discusses the use cooling methods for electric machines.
00:00 - Introduction
00:25 - Discussion on specifications with respect to cooling methods
04:13 - Discussion on Natural cooling or free convention
05:41 - Discussion on self cooling of self circulation
08:40 - Explanation of forced cooling with machine-mounted independent components
13:21 - Discussion on forced cooling with relative displacement
14:46 - Discussion on forced cooling with separate and independent components
22:18 - Types of cooling methods
28:15 - General standards applying to all machines
- Cooling methods for electrical machines are crucial for their efficient operation and longevity.
- The IC standard is used to specify the cooling method, circuit arrangement, and type of primary and secondary coolants in a machine.
- Different cooling methods are used based on the machine's requirements, including natural cooling, self-cooling, and forced cooling.
- Forced cooling can be achieved with machine-mounted independent components or separate and independent components.
- High power density machines often use liquid cooling due to its superior thermal conductivity.
