Obtaining Field Quantities from a Parametric Sweep
How do you obtain field quantities from a parametric sweep in Maxwell software?
This document demonstrates how to save the field quantities during a parametric analysis. It also shows how to display field values. As parametric analysis offers the possibility to sweep variables values and run a set of different simulations, the field result could be saved in setup and plotted in post-processing.
Solution Document:
