How do you export the simulation results and plots from Maxwell software?
When analysis is completed in Maxwell software, how do you export the simulation results and plots?
- Select Maxwell2D/3D > Results > Create Transient Report > Rectangular Plot.
- Select a Quantity of Category in the Report window and press New Report.
- When you right-click in the Plot window, Export and Export Legend show up. The Export feature saves a waveform as a .csv file with X, Y axis values, and the Export Legend option stores output data from Trace Characteristics.
Solution Document
