Charge Pump — Lesson 2
This lesson covers the concept of a charge pump and its role in building a phase locked loop. The lesson explains the phase detector, and the voltage-controlled oscillator. It also discusses the design of a circuit whose output is the difference of the phases of two voltages. The lesson further elaborates on the concept of a digital to analog conversion and the importance of a loop filter in a phase locked loop. It concludes with the limitations of the loop bandwidth and its impact on the performance of the oscillator.
Video Highlights
05:01 - Output and model of the phase detector
16:22 - Charge pump and its problems
27:38 - Velocity control and loop filter
35:50 - Open loop gain of the circuit
45:47 - Loop bandwidth and its significance
Key Takeaways
- The phase locked loop is a crucial component in frequency synthesis.
- The charge pump plays a significant role in building a phase locked loop.
- The phase detector is a unique component that is not a simple subtraction.
- The voltage-controlled oscillator acts as the plant for the control system.
- Digital to analog conversion is necessary for the output of the phase detector.
- A loop filter is essential in a phase locked loop to ensure stability.
- The loop bandwidth has limitations and can impact the performance of the oscillator.
