This lesson covers the dynamics of the phase lock loop in CMOS RF integrated circuits. It delves into the study of integer and frequency synthesis, explaining how a phase lock loop is built and how it functions. The lesson also discusses the importance of the loop bandwidth and how it affects the dynamics of the phase lock loop. It further explains the concept of lock range and settling time in the phase lock loop. The lesson concludes with an exploration of the integer N frequency synthesizer and the occurrence of spurious frequencies.
06:38 - Lock range in phase lock loops and its importance
17:16 - Phase error and loop bandwidth
24:55 - Digital clock and dividing the phase of a signal using a counter
49:26 - Mismatched phase and currents in the phase detector on the control voltage
54:03 - Output of the voltage-controlled oscillator when the control voltage has periodicity
- The phase lock loop is a crucial component in CMOS RF integrated circuits.
- The loop bandwidth plays a significant role in the functioning of the phase lock loop.
- The lock range and settling time are important properties of the phase lock loop.
- The integer N frequency synthesizer can generate spurious frequencies, which are unwanted signal frequencies that can interfere with the desired signal.
