Fabrics used in the composite material can be applied in specific layup combinations and orientations to provide the desired strength. A stackup of such fabrics can be created in Composite PrepPost prior to applying the material. In areas where high impact and strength are necessary, a sandwich structure of carbon fiber can be created by inserting core material between multiple stackups.
In this video, you will learn how to create fabrics and add structural stackups from composite materials and how to add rosettes for the different parts of a chassis.
