How to Update Properties of Boundaries – Lesson 3
Once the surface mesh has been created for the imported geometry, the properties of the boundary surfaces must be defined. This can be done through the Update Boundaries task in the Ansys Fluent Meshing watertight geometry workflow. In this lesson, we will investigate how to edit the boundary name and type using this task, as well as learn how to display boundaries based on their type or a custom set of selections. Also, we will learn how to merge boundary zones using the Add Boundary Type task in the workflow.
Alternate video link.
Simulation Files
Download the files here to follow the video step by step. The Ansys Student software can be downloaded for free here.
