Two-Port Antenna Case — Lesson 4
In this lesson, a two-port rectangular edge-fed patch antenna is simulated, case 8. It has two ports to simulate it as a part of a larger array. The results are analyzed to illustrate how antenna parameters are calculated and interpreted in multiport antenna cases.
