In this lesson, we will do a walkthrough for co-simulation linked design between Ansys HFSS software and circuit simulator to analyze an antenna with an integrated matching network, cases 6 and 7. The antenna is simulated in Ansys HFSS software, and the matching network is simulated in a circuit simulator. The co-simulation provides insights into how the antenna's performance affects and is affected by the matching network. The results are analyzed to illustrate how antenna parameters are calculated and interpreted in linked design cases.
