Bike Crank Design Tutorial with Ansys Discovery — Breakaway!
This course introduces you to the design and analysis of the crank arm used to pedal a bicycle. The bike crank must sustain the weight of the rider and should not break or deform. In this course, you will learn how to create a solid model of the bike crank starting from a simple sketch. Then, you will explore how to analyze the performance of different designs through simulations, performing structural analyses.
