Ansys Fluent Meshing Watertight Geometry Workflow
Current Status
Not Enrolled
Price
Closed
Get Started
Ansys Professional Certification
Description
Welcome to the Ansys Professional Certification for Ansys Fluent Meshing Watertight Geometry Workflow. You are on your way to set yourself apart with an official Ansys Professional Certificate! Before you invest in your certification, we would like you to review some important information below.
Once enrolled, you will be presented with five items under the Certification Content area. Please click on any of the items to start the exam.
You will have 30 days to all the items. Upon completion of the certification exam with a passing score, you will be rewarded with access to a digital credential. If you do not pass on your first attempt, you will have one additional attempt within the 30-days from the time you purchased the certification exam.
Details
Certification Exam
Two attempts to pass within 30 days from your purchase.
Consists of 1 theory-based test and 4 simulation-based tests.
Theory quiz is 60 mins in timed duration and is based on the course theory. Simulation or workshop quizzes, each being 60 mins, are based on simulation setups or workshops. Start any quiz, anytime within 30 days and complete each quiz in one sitting once you have started. A passing grade of 75% is required for all tests.
Software in the Cloud
Get access to student software in the cloud. Bypass the need to download and install software locally.
Certification exams are designed to run on the free Ansys Student product. By enrolling in the certification, you get access to 20 hours cloud access to the Ansys Student Product.
Digital Badge
Highlight your successful completion of the Certificate. Share digital credentials with your social and professional network.
Obtain digital credentials, issued by Credly, after successful completion of the certification. Credentials do not expire. No limit on the number of shares.
Recommended Courses
Ansys recommends the Ansys Innovation Learning Tracks titled “Ansys Fluent Meshing Watertight Geometry Workflow”, linked below, to prepare for the certification tests.
FLUIDS
LEARN Simulation
User Interface
FLUIDS
LEARN Simulation
Import Geometry
FLUIDS
LEARN Simulation
Add Local Sizing
FLUIDS
LEARN Simulation
Generate the Surface Mesh
FLUIDS
LEARN Simulation
Describe Geometry
FLUIDS
LEARN Simulation
Add Boundary Layers
FLUIDS
LEARN Simulation
Generate the Volume Mesh
FLUIDS
LEARN Simulation
Workshops
Terms & Conditions
By beginning or accessing this Ansys certification exam, you confirm acceptance of and agree to be bound by the Certification Terms and Conditions and all program policies, if any, provided or otherwise made available to You
