Real Viscous Flows
Ansys Associate Certification
🛈 Important Notice: This certification is no longer available for purchase. Check out our latest upgraded version here .
Description
Once enrolled, you will be presented with two sections under the Content area. Please click on either of the sections to start the exam.
You will have 30 days to finish both the sections. Upon completion of the certification exam with a passing score, you will be rewarded with access to a digital credential. If you do not pass on your first attempt, you will have one additional attempt within the 30-days from the time you purchased the certification exam.
Details
Certification Exam
Two attempts to pass within 30-days from your purchase
Consists of 1 theory-based test and 1 simulation-based test
First certification test is 60 mins and is based on theory
The 1 simulation-based test of 60 mins are based on Simulation setup
Start anytime within 30 days and complete in one sitting once started
Passing grade of 75% is required for all tests.
Software in the Cloud
Access free student software in the cloud for 20 hrs.
Bypass the need to download and install software locally
Designed to run on the free Ansys Student product
Can use standard commercial or academic license of Ansys software
Must use latest version of Ansys software Confirm that you can set up, solve and post-process any model before starting
Digital Badge
Highlight your successful completion of the Certificate
Share digital credential with your social and professional network
Digital credential is issued on successful completion
Requires an account on the credential-issuing platform, Credly
Credentials do not expire No limit on the number of shares
Recommended Courses
Ansys recommends the Ansys Innovation Learning Track titled "Real Viscous Flows” available for FREE here to prepare for the certification tests. This learning track comprises of following courses:Completion of Certification Exam
To enroll in this certification, please visit the Market space. Once enrolled, you will see the two sections under Certification Content below. Please click on either of the sections to start the exam. You will have 30 days to finish both the sections. Upon completion of the certification exam with a passing score, you will be rewarded with access to a digital badge. If you do not pass, you will have one additional attempt within the 30-days from the time you purchased the certification exam. By proceeding further, you acknowledge that you have read and understand the guidelines mentioned above and understand that this will be counted as one of the two allowed attempts.Terms & Conditions
By beginning or accessing this Ansys certification exam, You confirm acceptance of the Certification Terms and Conditions and all program policies, if any, provided or otherwise made available to You, and You agree to be bound by the Certification Terms and Conditions.
You are being redirected to our E-commerce site to provide you an optimal buying experience experience. Please refer to our FAQ page for more details. Click this link to proceed.
