Premium
Electronics
Optimization of Inductor Design using Ansys Maxwell and Ansys optiSlang Software (Tutorial)
2-4 HOURS
Traditionally, you might rely on manual parameter tuning and trial-and-error for inductor design. It can be time-consuming and may not always lead to the best design. This tutorial demonstrates a step-by-step workflow of inductor design optimization by combining accurate electromagnetic simulation in Ansys Maxwell® advanced electromagnetic field solver with automated design exploration using Ansys optiSLang® process integration and design optimization software. By applying this workflow, you can systematically search the design space and identify high-efficiency solutions much faster. This approach not only improves design quality, but also significantly increases engineering productivity.
Learning Outcomes:
Following completion of this tutorial, you will be able to:
- Automatize Ansys Maxwell software in EDT in the Ansys optiSLang application using the Solver Wizard.
- Derive scalar output Parameters from signals.
- Use Sensitivity and Optimization Wizards in Ansys optiSLang software to set up the Algorithms.
- Use Optimization on the MOP.
- Create a scalable and accessible Ansys optiSlang Webapp.
- Gain more background of Sensitivity Analysis and Optimization.
Prerequisites:
- Ansys Maxwell Getting Started course
- Getting Started with Ansys optiSLang Software course
Please note: These training materials were developed and tested in the 2026R1 release.
Cost: $450.00
- Course Duration: 2-4 HOURS
- Skill Level: Expert
- Skills Gained: Motor Assembly, Rotor Design, Coil Winding, Mechanical Analysis
