Events
General
Harnessing the Power of Workstation GPUs for CFD Studies
Category: Tag:
Overview
Many engineering teams assume that meaningful CFD acceleration with GPUs requires high-end, expensive GPU hardware. As a result, GPU adoption is often viewed as out of reach—especially for smaller teams or organizations working within tighter budgets.
What attendees will learn
This webinar explores how the Ansys Fluent GPU solver can enable significant speed-ups even using lower-end GPU cards or workstation GPUs, without requiring large capital investment.
You will learn:
  • Practical GPU hardware considerations, including how to select the right hardware for your budget and workload.
  • How GPU acceleration enables faster turnaround on common applications such as conjugate heat transfer, rotating machinery, and external aerodynamics, while maintaining the robust accuracy Fluent is known for.
  • Fluent GPU Solver best practices, use cases, benchmarks, and licensing.
By harnessing affordable GPUs, engineers can still achieve significant speed-ups—often equivalent to dozens or even hundreds of CPU cores—without compromising the accuracy required for high-stakes design decisions. Join our webinar to learn more.
Speakers
  • Sabrina Hafid
  • Rob Winstanley
  • Theresa Duncan
Date / Time:
June 11th, 2026
11 AM EDT
Venue: Virtual
REGISTER FOR EVENT
