Premium
Structures
Ansys Workbench LS-DYNA
$450.00
6+ HOURS
SKU: PL-ST-00062 Categories: , Tag:
This course covers the use of Ansys LS-DYNA® nonlinear dynamics structural simulation software inside Ansys Mechanical™ structural finite element analysis software. Ansys LS-DYNA software is useful for the analysis of problems involving contact, large deformation, nonlinear materials, transient response, and/or problems requiring explicit solutions. Common applications for which Ansys LS-DYNA software excels include safety and stability, crash test and drop test simulation, as well as forming applications.
Learning Outcomes:
  • Understand how the explicit solution method differs from other methods used to performed dynamic analysis in Ansys and to choose when it is most appropriate.
  • Choose the proper solution parameters unique to Ansys LS-DYNA software that will ensure an accurate and efficient solution.
  • Take advantage of common modeling abstraction techniques (rigid bodies, point and distributed masses) to produce efficient and realistic simulations.
  • Understand and apply various Contact conditions unique to Ansys LS-DYNA software according to best practice guidelines.
  • Leverage the robust nonlinear analysis capabilities afforded by Ansys LS-DYNA software in the solution of quasi-static problems.
  • Assign mesh controls required to produce accurate and efficient explicit solutions.
  • Choose from several Ansys LS-DYNA software element formulations while understanding the trade-offs between accuracy and efficiency. Use SPH to solve problems involving granular or fluid-like materials.
  • Access advanced functionality of Ansys LS-DYNA software using keyword snippets.
Prerequisites:
  • Ansys Mechanical: Beyond the Basics
  • If you have not done analysis using Ansys LS-DYNA software, then we recommend you taking Ansys Workbench LS-DYNA Getting Started first.
Please note: These training materials were developed and tested in the 2023R1 release.
    $450.00
  • Course Duration: 6+ HOURS
  • Skill Level: Beginner
  • Skills Gained: Explicit dynamic analysis, Quasi-static simulation, LS-DYNA keyword scripting, Mesh control strategies, SPH material modeling
