R&D Verification Engineer II - Remote f/m(16762)
Key Duties and Responsibilities
  • Specify and write test cases, creates, modify and update existing tests, write and maintain test scripts
  • Perform functional, application, regression and white box testing in manual and/or automated test environments and investigate possible causes of problems
  • Automate testing activities at both the application and source code levels
  • Contribute to expanding test coverage, monitoring daily test results, and diagnosing root causes of test failures
  • Be an active and flexible team member, ensuring the success of our projects
  • Create test plans, participate in defect management and testing metrics
  • Apply standard techniques and procedures and comply with the company's overall development and testing processes​
  • Work in a variety of computing environments: Windows, Linux
    0
    Your Backpack
    Your backpack is empty
