USD ($) ^
Learning Path
Photonics
Ansys Lumerical FDTD
FREE
6+ HOURS
7 COURSES
SKU: TBD-PH-00007 Categories: , Tag:
In this learning track, we will learn about Ansys Lumerical FDTD and see how to set up, run and analyze a simulation. We will first discuss the underlying solver physics and numerics of Ansys Lumerical FDTD, the types of problems it can solve, and how it can be best used for parallel computation. Then we will learn about the default materials and material models, as well as how to add additional materials to the material database. Following this, we will take a look at the Ansys Lumerical FDTD solver region object which is used to specify the simulation time, the simulation region, mesh, and boundary conditions. We will also learn about the available types of sources and the various types of monitors, and their recommended usage in Ansys Lumerical FDTD. Finally, we will learn how to view simulation results, plot, and export data, how to perform additional post-processing of monitor results using analysis groups, and how to verify the accuracy of simulation results in Ansys Lumerical FDTD.
A track completion digital badge allows you to showcase your expertise and get recognized globally. We partner with the Credly Acclaim platform. Digital badges can be used in email signatures, digital resumes, social and professional media. The digital image contains verified metadata that describes your participation in the specific learning track consisting of multiple courses. This digital badge is for successfully completing the Ansys Lumerical FDTD track.
    FREE
  • Course Duration: 6+ HOURS
  • Skill Level: Intermediate
  • Skills Gained: Ansys Lumerical FDTD, FDTD Algorithm, Solver physics,
