USD ($) ^
Course
Structures
A Stepped Shaft in Axial Tension
FREE
1-2 HOURS
Cornell University
SKU: BDG-ST-00002 Categories: , Tag:
Stepped shafts are widely used in drive trains.They are generally holding large gears and cams, which are key elements in power transfer. Mostly supported by bearings at the end, the shaft experiences bending loads, axial thrust and torsional loads. The shaft must have greater strength to withstand these loads.A factor of safety is used to design the shaft so that higher loads limits are assumed than the working load limit. With gears and cams engaged with other parts in the assembly, any deviation in the shaft's shape can cause a catastrophic effect.The assembly could fail long before the shaft reaches its failure limit and, therefore, the study of the shaft is extremely important. This SimCafe course was developed by Rajesh Bhaskaran, Swanson Director of Engineering Simulation at Cornell University in partnership with Ansys; it was last modified by Sebastien Lachance-Barrett. It serves as an e-learning resource to integrate industry-standard simulation tools into courses and provides a resource for supplementary learning outside the classroom. The following course shows how to estimate the axial stress concentration on a stepped shaft under axial tension using Ansys Structural.
For more ways to learn, check out the Cornell edX course, A Hands-on Introduction to Engineering Simulations at ansys.com/cornell.
Cornell University also offers a Fluid Dynamics Simulations Using Ansys online certificate authored by Dr. Rajesh Bhaskaran. Learn more here: https://ecornell.cornell.edu/fluiddynamics
A course completion badge allows you to showcase your success. We partner with Credly’s Acclaim platform, and digital badges can be used in email signatures, digital resumes and social media sites. The digital image contains verified metadata that describes your participation in our course and the topics and skills that were covered. This badge is for successfully completing the A Stepped Shaft in Axial Tension course.
    FREE
  • Course Duration: 1-2 HOURS
  • Skill Level: Beginner
  • Skills Gained: Stepped Shafts, Structural Analysis
