USD ($) ^
Course
Forced Convection in External Flows
FREE
4-6 HOURS
SKU: BDG-FL-00014 Categories: , Tag:
Forced convection heat transfer refers to a process in which fluid flow generated by external means, such as a fan or an externally imposed pressure gradient, extracts or imparts heat from or to objects at temperatures different from the flow temperatures. Forced convection is commonly used in applications such as cooling of electronic components by fans, heating of homes using forced air blowers, cooling of oil and coolants in vehicles using externally forced air, etc. In this course, we will first look at some fundamental aspects of forced convection and then go on to discuss the finer details regarding the velocity and thermal boundary layers. Finally, we will analyze the forced convection heat transfer in certain external flows such as flow over a flat plate, cross-flow over a cylinder, cross-flow over a tube bank, and impinging jet flow.
A course completion badge allows you to showcase your success. With our badging platform, digital badges can be easily shared in email signatures, digital resumes, and social media profiles, helping you highlight your achievements. The digital image contains verified metadata that describes your participation in our course and the topics and skills that were covered. This badge is for successfully completing the Forced Convection in External Flows course.
Alternate video link.
    FREE
  • Course Duration: 4-6 HOURS
  • Skill Level: Intermediate
  • Skills Gained: Forced Convection, Heat Transfer, Ansys Fluent
