Tagged: 19.1, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 1:10 pm
SolutionParticipantThe Fluent boundary conditions “exhaust fan” and “intake fan” allow to include external fans or pumps to your simulation. Essentially you provide the fan or pump curve in the form pressure rise as a function of velocity normal to the boundary. The manual doesn’t give details if you need static or total pressure and it is also silent about post-processing. The attached document tries to fill this gap.
1. 2055306.pdf
2. 2055306.zip
- Skewness in ANSYS Meshing
