March 17, 2023 at 9:00 am
FAQ
ParticipantPlease check under the Environment variables on the machine for XERCES_DISABLE_DTD if it’s set to 1. If so, remove this variable and that should fix the issue. The issue is due to the above variable blocking DTD processing for XML documents.
- Q: How do I set the license server from my client machine?
