Workbench Explicit Dynamic 2019 Rx or 2020 Rx (may also happen in 2021 Rx) running on UGE remote Linux viz node, submit RSM job to localhost for UGE job, solving may hang or finish without actually solving, no result files generated.
January 25, 2023 at 7:28 am
FAQParticipantBackup and edit {shared_installed_path}/vXXX/RSM/Config/xml/hpc_commands_SGE.xml, change the “-V” flag to “-v AWP_ROOTXXX” in line #46. For example from:
%RSM_HPC_NATIVEOPTIONS% -S /bin/sh -V … To: %RSM_HPC_NATIVEOPTIONS% -S /bin/sh -v AWP_ROOT202 …
