Workbench crashes with segmentation fault on SuSe 10 when trying to start using the ./startpage command. ./startpage line 9: 17310 Segmentation fault /ansys_inc/v100/aisol/workbench -Startpage $* Why is he getting this error?
March 17, 2023 at 9:01 am
FAQParticipantWe do not support SuSe 10 or 10.1 in WB 10 and WB 11.0. We only support SuSe 9.
