Workbench 2020R2 GUI and Spaceclaim2020R2 GUI do not appear when running these products from the Windows 10 Start Menu. No warnings or errors are shown.
January 25, 2023 at 7:28 am
FAQParticipantOpen Windows event viewer “C:ProgramDataMicrosoftWindowsStart MenuProgramsAdministrative ToolsEvent Viewer.lnk” Action Refresh Windows Logs Application Action Refresh If entries exist for ANSYS products and the errors shown include BEX64 Right Mouse Click each of, C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R2SpaceClaim 2020 R1.lnk” C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2020 R2Workbench 2020 R1.lnk” and choose Trouble Shoot Compatibility Try Recommended settings Test the program If the ANSYS software open OK. Next Yes, save these settings for this program. If the ANSYS software still fails Next Cancel
