March 17, 2023 at 1:10 pm
SolutionParticipantPlease see attached video for solution. You can also check solution # 2043646 for best practices for prism generation. Keywords: invalid normal, skewness, ortho quality, bad elements, prism, sharp angle
1. 2050739.zip
- Skewness in ANSYS Meshing
