Within a Fluent UDF, how can I calculate the total heat transfer rate (radiative + convective), radiation heat transfer rate, or the absorbed radiation flux on surfaces?
Tagged: 16, Advanced Macros, fluent, fluid-dynamics, General - FLUENT, udf, user-defined-functions
January 25, 2023 at 7:16 am
FAQParticipantUse the following macros 1. BOUNDARY_HEAT_FLUX(f,tf) to obtain the total heat transfer rate 2. BOUNDARY_RAD_HEAT_FLUX(f,tf) to obtain the radiation heat transfer rate 3. F_DO_QA(f,t,nb) to obtain the absorbed radiation flux when using the DO model Note that “FLUX” in the macro is a misnomer and it gives the total heat transfer rates in watts and NOT the heat flux in watts/m2. C_ABS_COEFF(c,t) gives you the absorption coefficient at a cell. This is not the same as the absorbed radiation flux at the wall.
- Skewness in ANSYS Meshing
