June 6, 2022 at 8:33 am
FAQParticipantThe non-gray DO model specifies that BOTH radiation absorption and emission occur at different wavelength bands. These bands are specified in the non-gray DO model settings. In the wall boundary condition, instead of the wall Internal Emissivity being under the Thermal tab, it is now under the Radiation tab. Since wall emission of radiation also occurs at the wavelength bands set out in the model, there is now one emissivity for each band. The default value of these band emissivities is always 1.0. This is not a bug: band emissivity will generally differ from spectrum average emissivity. However, since the overall Internal Emissivity for the two setups is different, thermal results will differ.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
