With Fluent release 2021 Rx and using a Linux Job Scheduler without relying on a standard Fluent option for job submission the Fluent job will only run on one node on the cluster.
Tagged: 2021 R1, fluent, FLUENT - SYS, HPC/Parallel, Installation/Licensing/Systems, lsf, N/A, pbs, SGE
January 25, 2023 at 7:28 am
FAQ
ParticipantThis issue is related to a change which was only documented for SGE though it applies to LSF and PBS Pro as well. 3.3. Using Custom SGE Scripts If you use custom SGE scripts instead of relying on the standard Fluent option (either the -scheduler=sge option from the command line or the Use SGE option in Fluent Launcher, as described in the preceding sections), your environment variables related to the job scheduler will not be used unless you include the following environment variable in your script: FLUENT_LM_CHECK_ENABLE=1. https://ansysproducthelpqa.win.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_lm/flu_sge_parallel_sge_sumbit_fluent_scripts.html Also, this is further enhanced in 21.2 and documented for all schedulers.
